TractorLinks.com
Order Ford 600 Parts Online
Ford 3600 Front Blade Lifts/Works, 3 Point Won't Lift
jkoptionsbroker
09-13-2018 09:29:34
1977 Ford 3600 - Gas Engine
New to me tractor, was used by the city for snow removal. It has a hydraulic snow blade that is run off what looks to be a Ford factory remote (possibly made by tisco). The front hydraulics work great, but the 3 point is not functioning properly. It will only lift if you move the draft position up, the position control does nothing to lift it.
I thought there might be a diverter valve, but can't seem to find anything. The fluid is full and I think with the front hydraulics working great, that is probably not a pressure problem.
Any ideas of where to start, I have a video, but haven't figured out to include it.
Thanks
Sean in PA
09-19-2018 16:27:53
 Re: Ford 3600 Front Blade Lifts/Works, 3 Point Won't Lift in reply to jkoptionsbroker, 09-13-2018 09:29:34
I believe that the remote is upstream from the 3 point hydraulics in terms of float, so something could be stuck open in the 3 point circuit, like the unloader valve, or something could have broken or dropped out of position on the internal linkage.
BigPapa53
09-18-2018 16:25:28
You just had to spoil it for me, didn't you...... :lol:
Sean in PA
09-18-2018 12:16:07
Re-read the post. There is no loader, just a plow blade on the front.
BigPapa53
09-18-2018 12:10:24
I have determined that you need to remove the loader. This will alleviate the issue.
I can come and pick it up to get it out of your way anytime you like...... :wink:
Destroked 450
09-18-2018 08:46:42
If it's plumbed into a standard remote valve does that valve raise and lower the blade or does it have another valve to control the blade?
jkoptionsbroker
09-19-2018 13:22:40
 Re: Ford 3600 Front Blade Lifts/Works, 3 Point Won't Lift in reply to Destroked 450, 09-18-2018 08:46:42
The remote valve raises/lowers front blade and it works perfect.
jkoptionsbroker
09-18-2018 08:14:40
There is no auxilary service valve that I can see in this remote. It appears to be a ford factory remote as it is the same remote in the manual.
The flow control valve is pointed around 2:00. Does it the flow need to be turned up?
sotxbill
09-15-2018 14:48:36
Is your aux services valve pulled out?
Texasmark1
09-17-2018 14:48:46
 Re: Ford 3600 Front Blade Lifts/Works, 3 Point Won't Lift in reply to sotxbill, 09-15-2018 14:48:36
If one of us nailed it for him, he's a lucky man. Wink!
Texasmark1
09-15-2018 13:04:30
How about your flow control valve on the right side, half way down the casting, 2" sorta knurled, plastic, knob. How far is it from all the way CW?
jkoptionsbroker
09-13-2018 09:32:26
I unable how to figure out how to post video, but if you search you tube for "Ford 3600 3 point lift problem"
It should be first result. thanks
