my 3 cyl 3000 is running lean and causing it to run a little hot and low power . yesterday I was cutting hay pulling a 479 conditioner had plenty of power and temp was fine and running cooler and more power than usual . Finished the first field shut tractor off for a hour or so and started second field and notice loss of power and temp running close to the red. still able to cut hay but had to drop a gear. I think its been running a little lean for a while but first field yesterday was the best its ran in a while. I'm going to clean the gas filters and all screens.Which carburetor screw is the lean /rich screw? Does anyone have any thoughts or advice? Yesterday when I Started was the best and the coolest the tractor has ran in a good while
Thanks for the help Joe
