TractorLinks.com
Show Parts for Model:
Need help with Ford Hydraulics
willjohnfrank
09-12-2018 15:35:22
I am trying to add a HV4902 Adapter plate that says it's for a Ford 3000 to add remote hydraulics. I plan on using this for a front end loader in the near future hopefully. All the holes on the plate are accounted for I put the o rings in place bolted everything up and now my rear hydraulics do not work. There is also a small leak from my hydraulic pump when I run it for a while like this. I removed the adapter and put just the original plate back and the problem was solved. My rear hydraulics worked and the leak was gone. It seems like something is being blocked somewhere. Does anyone know what could be happening?
motzingg
09-14-2018 14:07:14
 Re: Need help with Ford Hydraulics in reply to willjohnfrank, 09-12-2018 15:35:22
This is what we were told when i worked at a hydraulic testing/ research institute, but i was always skeptical. I don't think a few little shreds of teflon tape could cause much damage in the kinds of systems we are talking about. Now maybe if you horked a bunch of the stuff in there or had a modern fancy system with tiny pilot valves and electric solenoids, it could be a problem.
Use a thread sealant paste made specifically for hydraulic applications (not plumber stuff) and fully fill the first 2-3 threads of the male. Parker corp publishes a lot of really good free materials you can get from a parker store/distributor or free online that explain everything from o-ring selection to how to braze fittings... if you want to get it 'from the horse's mouth' i'd go right to them. There is also a torque spec specified as '# of turns past hand tight' that you will want to pay attention to, you can definitely over-torque NPT and cause problems.
Sean in PA
09-14-2018 12:38:58
I was taught by my brother-in-law, who is a master plumber ... "dope (what you call paste), then tape, then dope" That allows you to barely tighten NPT threads to a little more than finger tight and they will never leak. Also makes for easier disassembly later. Just make sure that you start the tape at least two threads from the end of the male fitting and no tape will be able to get into the system.
Johnofnewhaven
09-12-2018 17:27:00
WayneIA is correct and don't run your tractor till you loop the two fittings together. When I don't have my quicktach loader on I hook the two hoses together. One male one female. See photo.
willjohnfrank
09-12-2018 20:12:05
 Re: Need help with Ford Hydraulics in reply to Johnofnewhaven, 09-12-2018 17:27:00
Do you guys use Teflon tape I was told not too but there are some leaks. Any idea how to make them all stop?
Texasmark1
09-14-2018 06:44:47
 Re: Need help with Ford Hydraulics in reply to willjohnfrank, 09-12-2018 20:12:05
Teflon is not recommended as it apparently has gotten stuck in valves causing them to leak whereby paste doesn't. Do not know/remember the origin of the caution note but I have observed the reason why......and I love that, not being told "not to do" something without having the reason stated so that I can make my own decisions about what I am to do. So I use paste.
Johnofnewhaven
09-13-2018 08:44:34
I use Teflon. You just want to start the Teflon back of the end of the threads as to not get any Teflon in the hydraulic system.
WayneIA
09-12-2018 16:36:51
Tie the two fittings together with a hose. You have the system deadheaded now!
Texasmark1
09-13-2018 06:23:30
 Re: Need help with Ford Hydraulics in reply to WayneIA, 09-12-2018 16:36:51
I have a 3000 and bought a block from Ford which was used on an industrial tractor. I connected it to a Cross Open Center control. I don't have the outlet connections connected to an implement or jumpered.
In writing this it is occurring to me that the Cross is doing the bypassing for me (in-out ports) that I would otherwise have to have a jumper hose as you are referencing. Without the bypass, fluid can't go on to the 3 pt lift arms so for that installation pictured, without anything hooked up to the block, the pump is driving against the over pressure (pop-off) valve in the hyd system and everything is getting stressed and hot....yes/no?
willjohnfrank
09-12-2018 20:07:40
Thank you guys so much! This is a great forum. I really appreciate the quick response brothers
riveroadrat
09-13-2018 13:24:25
 Re: Need help with Ford Hydraulics in reply to willjohnfrank, 09-12-2018 20:07:40
You cant beat a front pump mounted loader for performance.
