FORD NAA/GOLDEN JUBILEE WIRING
Yergntiger93
New User
I purchased a 12 volt harness for this NAA. It is a NAA10301 harness. Does anyone have a wiring diagram for this harness or has anyone used it for a conversion? I have removed all wiring to include the voltage regulator but kept the 6v starter. I have the alternator mounted and would like to get this old girl running. Any help would be appreciated.
Very few wires. Colors differ by manufacturer.
JMOR
What would change with a 3 wire hook up. For some reason I was thinking red would go back and tie in the hot batt post in at and white wire would go to amp Guage
(quoted from post at 19:09:10 09/11/18) JMOR
n my diagram, the #2 alternator spade would tie to the output stud (yellow) and #1 would pass thru a diode or a small lamp (idiot light) and then to switched side of ignition switch.
[This quote="JMOR"](quoted from post at 15:05:24 09/11/18) Very few wires. Colors differ by manufacturer.
[/quote] This diagram looks really simple and easy to follow. I just inherited a Golden Jubilee and wonder where on this diagram is the battery and connections. My father in law passed away with dimentia and really had this wiring messed up. Thanks.
(quoted from post at 19:05:43 07/23/23) [This quote="JMOR"](quoted from post at 15:05:24 09/11/18) Very few wires. Colors differ by manufacturer.
This diagram looks really simple and easy to follow. I just inherited a Golden Jubilee and wonder where on this diagram is the battery and connections. My father in law passed away with dimentia and really had this wiring messed up. Thanks.[/quote]his diagram is for a tractor that has been converted from 6v Positive ground to 12v Negative ground with alternator instead of original generator. If that is what you have, then the battery Positive connects to solenoid terminal that I have labeled BATT and the battery Negative bolts to the tractor chassis, (engine, steering box, etc.)
