Ford 4500 industrial hydraulic pump
Badburn
New User
Hi guys, I've got a 1968 4500 loader backhoe here. It broke the 13 spline input shaft off of the Vickers pump located up in the front of the tractor. From what I've learned so far, there was a 1966-1971 pump, and then a 1971-1975 or so pump that mounts up in the same location, but has different connections for the inlet and outlet.
It looks like the early pump is no longer available. I can buy the later pump here at yesterdays tractors, but have not been able to locate the conversion parts, which consists of an outlet tube and an inlet flange.
Has anyone had experience with this, or have any hot tips for getting this thing back up and running?
Thanks for the replies guys. Is this the gear pump you are referring to?
Hydraulic Pump Part Number D1NN600B
http://www.yesterdaystractors.com/Ford-4500_Hydraulic-Pump_D1NN600B.html
(quoted from post at 17:10:06 09/10/18) Thanks for the replies guys. Is this the gear pump you are referring to?
That is the gear type pump (48.51cc), the new CNH part number for it is 87607369.
