got a 1987 6610 that is grinding gears, dont do it all the time if i can time it right and shift straight from reverse to a forward gear just as it is barely moving. but from a stand still it will normally grind going in. and on the road it grind going into 3rd and 4th. all i see in manual as far as adjustment is the clutch freeplay, is that the only adjustment you can make?
and also when cutting and raking hay i have noticed that the transmission area gets really hot, is that normal for these tractors? my other tractors get pretty warm after several hours in hot summer heat but this one is good bit hotter.
