Ford 801 power steering control valve
riveroadrat
does anyone know if the ball in this check valve is spring loaded or just moves back and forth? Ford item number 41 SEAT/SLOT Seat, 3/8", Valve to Pump Pressure Tube E1NN3N963AA. You can see this part when you take out the one fitting with the oring in the pressure port. The ball can be seen when the center spool is removed. I am also looking for one horned plunger and two plunger springs if anyone has some spare parts.
