Ford 5000 fuel leak
That's not supposed to be fuel. That part of pump has oil in it. usues same as engine.needs to change at oil change. There is plug on bottom that drains and in front of throttle stops is another plug that's the full mark. Fills with hex plug on top of pump. The bolt that goes in there is 5/16-24 with cross drilled and end drilled hole along with tube with curl in it. Avaible from CNH.
Tube is #90 in the link below.
Fuel leakage out of this point is very common. Without getting into a lot of detail, it basically means that you need to change your pump oil
more often.
Tube
