Jim 67 3400
New User
Over the winter I got some rain and or snow in the cylinders and crank case I have since drained it out flushed with fresh oil drained that, I put more fresh oil in but I am having trouble getting the oil pressure light to go off. I modified a spin on filter to plug the oil supply to the engine and blue compressed air through the new clean filter to try to blow out the oil pump if sludge got in there but that hasn?t worked either. I really don?t want to have to drop the oil pan and pull half the tractor apart is there something I can do to the oil pump to manually spin it? There is an oil drive gear cover that accesses the oil drive maybe I can pull that gear and ride out and spend the oil pump manually?
Thank you in advance for your help look forward to hearing from someone!
Jim
Jim
