ford 2000 industrial backhoe 1964 4 cyl gas
rat0851
I need to change fan belt on 1964 Ford 2000 industrial backhoe with front hyd. pump and loader. wondering what the best way is to do this or is there more than one way ? thanks Randal
I will soon have to replace the belt on my 2000 loader tractor. Looking at this one, pull pump back and slide in there.
(quoted from post at 05:42:59 09/05/18) I need to change fan belt on 1964 Ford 2000 industrial backhoe with front hyd. pump and loader. wondering what the best way is to do this or is there more than one way ? thanks Randal
I have a '64 Backhoe also and what I did was purchase an adjustable fan belt ( the ones that come apart and you put them back together as per your fittment length... Worked fine for me and easy and quick... draw back is they are more expensive then the regular belts , but they worked just fine .. my 2 cents
