baxternick
New User
My Roosa Master has started leaking non-stop around the seal between the head and body. The pump is the style pictured below without the automatic timing on the side. The tractor is a 59 901. I can't find an exploded view of my pump, only the newer version. I am going to attempt to tackle this myself as I have had the pump apart and off numerous times for metering valve issues. I just want to make sure that the allen keys/cover on the side of head facing forward won't cause a run away engine after rebuild. I also wanted to see what is located under the cover. Any help would be appreciated.
