Mike Knowles
I had to replace the clutch. So I took everything apart even the steering column. (not a good idea, removing the drag links made the sector shaft seals leak). I replaced the PS pump with a 65 Mustang or Thunderbird pump $65. Upon filling the PS system, the lower steering column shaft seal leaked. The SS spring had broken. Luckily, I found the upper (c5nn3n739a) and lower shaft seal (e1nn3n62aa) as well as the 2 O-rings (87150s94) and installed them. Yes, you can loose a few of the ball bearings, be careful. I think Murphy had been working along side me.
I had taped the power steering hoses with tape as the upper hose to the control valve on each side. One tape fell off. Seems like there was one best way to fit them up.
I thought I should check before starting it back up, because of Murphy. I found a hose diagram for the 600 and the 800 series. My left cylinder matches the drawing and line connections. The right cylinder angled port #2 is on the inside but, the lines still match.
Can anyone confirm that the diagram is proper for the 801 series? I have a 841d or a early 4000 that looks like a 801 but was yellow and red.
Thanks, Mike
[/img]
Thanks, Mike
[/img]
