Anadolu power steering adjustment ?
Bart CA
On a 1966 Ford 2000 3 cyl diesel with Anadolu add-on power steering.
It is little hard to turn left. There is an Allen head bolt with locking nut
adjustment?) ont the actuator valve on the cylinder the bolt pass trough a slide
probably to avoid valve tipping. Is this bolt is an adjustment or only to avoid valve tipping.
If this bolt is an adjustment I will appreciate to have the adjut procedure.
I purchased this tractor few years ago previous owner did not have any instructions on
the Anadolu kit.
Thank you in advance
Bart CA
