Hydraulic lever, Ford 800
Jim TN
Need to replace friction material and lever is froze to the shaft. Since its pot metal, whats best way to free it, pull it off the shaft to replace friction disc?
I fiddle farted with one and still broke it. Next time I will start out ordering a new one. Heat and oil didn't help for me.
I have got several dozen are more off with a propane touch heat real good and pry with a couple of big arse screwdrivers... It does not take much force to work it off once you get it hot enoufh if you get mean you will break it... Patience heat and pry replete as needed...
I do not use any OIL NO OIL AT ALL it helps if the friction dist falls our, burns out are to push it out do not put any damm oil on it! Heat is your friend :)...
