Tie rod end
Ford900
I have a ford 960 with a bad tie rod end where is hooks to the steering sector arm. Does anybody know where I might be able to find one
Thanks, Bill. I've replaced a few of those, but I never called them that. I learn something every day.
Butch
(quoted from post at 04:27:44 08/28/18) You may have an easier time sourcing the correct size Heim joint as I understand the stud is not tapered like most tie rod ends.
[b:b6903b7276]Heim Joint[/b:b6903b7276]
Thanks for the link Bill, looks handy.
Yes, the stud is straight, not tapered. and the threaded portion is short, so it doesn't hit the tin.
A few years back I looked endlessly for the proper one, no luck.
Check online vendors part numbers carefully. Some list one for the 900, but a check of their part number shows a standard tapered end....won't work.
