rumblecloud
The Starter Relay gets pretty hot when cranking. Is this normal?
I have one wire prolly from the key ignition and the Positive battery cable on one side of the relay with the negative cable on the other. There are other wires on the back side but haven't been able to trace them yet.
If I don't separate the from the Positive battery cable from the Key Ignition wire with a spacer of some sort - even a washer - it shoots sparks and gets unusually hot.
I don't think this is normal . Can anyone offer any insight? Thanks in advance.
R
R
