861 fuel shut off valve
KennyCase
Is there a good kit to rebuild the shut off valve? It?s finally
leaking and needs a rebuild. Any and all help is appreciated.
No, no kits available. If it is the screw type you can rebuild it yourself by removing the stop pin by gently prying it out with the edge of a knife, tapping the hole for a #10 screw and putting a new O-ring of the screw. Make sure you use a Viton O-ring The #10 screw needs to be the same length as the pin as it acts as a stop so the shut off screw is not inadvertently screwed out too far. I've not read of the lever type valve being rebuilt by anyone and have not taken one apart to see if it is possible. Hope this helps.
If yours is a lever type you should replace it with a screw type. The lever type are likely to leak right out of the box.
