My 2120 has a set of rear remotes controlled by a valve located next to the 3 point valve. I have a hydraulic winch that was set up as a fixed mount on the tractor. Needless to say it was a real pain to put on/off. Just finished rebuilding the winch so I can use the 3 point hitch to raise and lower, came out great- easy on/off but... When I plug into remotes I have to clamp the hydraulic valve on the tractor open so I can use the valve that is on the winch, this disables the 3 point lift. Not sure what to do here, I have to be able to power the winch in and out in order to let pressure off to freespool. The winch is driven with a hydraulic motor. Assuming the tractor valve is double action, could I plumb direct to hyd motor, bypassing the winch valve? Are there open/closed center issues here? As you can see I'm not much on hydraulics and appreciate any help!
