Ford dual adapters
johnofnewhaven
Found these on Craigslist. North East Indiana. NOT MINE. Seems like a good price. They are close to my location. If anyone is interested I would be happy to go pick them up for you. I am not looking for a profit
Says they came off a 860. They want $75. Tried to copy the whole ad but can't figure out how. They are in Ossian Indiana.
They're not dual adapters. They are axle extensions used on all-purpose tractors to enable a full range of adjustment of the early power adjust wheels. Without these, the tires and rims could not be spun to the inner position of the screw. These were needed to provide clearance inside the tires/rims.
Furthermore, they're not in great shape. The lug bolts hanging in them with nuts on - those should be a light press fit in thlse spacers and not hanging loose like that.
Like Larry says, wheel spacers for utility tractors with PA rims.
Not useful for duals.
Dean
As others have said not correct set. here is a photo of the right ones for duals. As Larry said lug nut bolt would have been pressed it. Somethings not right there. Maybe he knocked the pressed in bolts out to put longer bolts it to try to mount dual wheels. Don't even know if it possible having the correct set I've never tried it with the extensions.
<a href="https://imgur.com/V2vFqne">
V2vFqneh.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/BbZBw2t">
BbZBw2th.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/sl7qOiA">
sl7qOiAh.jpg" title="source: imgur.com"
</a>
