Ford9000puller
born2farm
I got it.
I need a complete breather, draw bar and hanger. Power steering pump. To drive it will I have to take that arm off and put a non power steering arm on it? Runs good, lift works and the brakes work.
I installed a 69 Ford 4000 drag link on mine and its the perfect length. The only difference is the front link has a taper fit instead of a straight shaft. You might have to weld you a drop drawbar. The hanger off a 601 series will work.
Congrats on the new tractor!
The long drop drawbars come up on eBay once in a while, but the
only time I see them affordably priced is when the seller doesn't
know what they are. The hangers are different lengths between models too.
I can take some measurement for you if you want to make your own.
I may have a pump too, but I'll have to test it to see if it's good.
Royse thanks,when you have time let me know about that pump. If I get a pump I want need to change the steering rod. Will the draw bar assembly off any of the row crops work? Are will I need it off a certain one?
I forgot to add if those are Safemark tires they are made of very good rubber and only get very small cracks over many years.
"Will the draw bar assembly off any of the row crops work?"
I believe most of them would interchange. They will between
my 960 and 4000 rowcrops so I would think a 9x1 would also.
Has 4000 tin on it. Antique tractor around here mare only before 1959. The 4000 didn't start until '62
Will the air breather assemble have to be for a 2000 or will one of the other model be the same? I noticed that the hose on a 4000 has a metal pipe with a rubber hose on each end, and the 2000 has a rubber hose only.
Looks good. Lots of potential. The air cleaner will be different than a 4000. The tube size is smaller on a 2000 and it is different shaped. Problem is the correct one will be only found on a row crop 2000 or 701 and might be hard to find.
