Ford 8730 tractor with 18 & 9 power shift. Recently got fault codes "H3' and "H5" appearing on my transmission shift indicator. Looked up what I could find out about them and appears they indicate a fault with the ERPM solenoid (but why two codes for that?). Would like to see if there is a wiring issue before I replace the solenoid but none of the parts people can show me where the solenoid is located. I've checked the electrical and engine schematic drawings from Ford New Holland site but I cannot figure out where the solenoid is located. They show it on the side of the engine. Spoke with two Ford ag mechanics. One said if might be located at the back of the fuel pump another said it was located on lower chassis by the oil reservoir. Can anyone give me some direction for its location and can anyone offer a heads up about what these codes might mean. I am still operating the tractor. Have engine RPM and ground speed still indicating on electronic dash but shifting seems to be less smooth and clutch release is quite abrupt in higher rpm compared to before the fault indication.
