Ford 7412 Loader
fordman81
I have a Ford 7412 Loader I recently bought minus any attachments. I need to find a bucket but I don't know what to call the quick attach. Does anyone know what kind of quick attach did Ford use on these loaders? I have found a pic online of a loader with the same quick attach. I will try to attach it to the post. Thanks
I have a 7514 on an 8670 Genesis tractor. These loaders were made for Ford/New Holland by Shwartz. Schwartz became Alamo/SMC. They were located in Sioux Falls, South Dakota the last I knew.
If I don't miss my guess, the quick attach (which as far as I know has no special name) is no longer available as a new part. You may have to have those fabricated for however many attachments you want, unless you can find some aftermarket manufacturer that will provide them.
While not the same as the one pictured, Westendorf makes a quick-attach that can be added to most loaders. Quick and easy to use,
no tools once it's on there. Bad part is, it's expensive, and only takes Westendorf attachments.
