Bigron
I recently bought a 4610.
I cant find the year it was manufactured or hp.
The only numbers I could find are 7j29b. Eh70a07. Any help would be great
7J29B is a manufacturing date code for a part of your tractor, depending on where you found it.
If this was on the pad above and behind the starter, or listed as the ?unit? on the under hood sticker
It?s a September 29, 1987 second shift production for the tractor, so at least you know it?s a 1987 model
tried to send photo. Didnt work. Tag under hood says
Tractor number bb34503
Model ds314d
Unit 7k06b
Engine 983847. 7k06. Hopefully this better defines the year and hp
DS314D
DS3 = 4610SU special utility
1 = Diesel engine
4 = Independent 540 pto
D = 8x4 synchronized trans
7K06B = tractor built Oct 06, 1987 during day shift
4610SU is a low profile 4610 with swept back front axle from a 3610 and 28" tires
I have the older 4000SU model of your tractor.
Nice tractor. Very desirable for tight spaces when more HP is needed than with the smaller 2xxx/3xxx series of tractors. It has the larger 201 ci engine and double reduction rear axle with the wet inboard brakes of the 4000/4600/4610 series and the radius rod front axle and steering of the smaller 3000/3600/3610 series which gives it a tighter turning radius than the heavier straight front axles of the regular 4xxx series tractors.
