mounted a new spool valve on a '78 ford 3600 w/Dunham Lehr FEL, using the internal hydraulics. tractor has a 2 circuit auxiliary valve. valve install went great and the loader bled out very easy. one problem appeared, that i didn't have with the old gresen valve.
when the bucket curl reaches its maximum travel in either direction, it pops off the auxiliary valve back to center position (off front end loader). this may be happening with the lift cylinders also, but didn't experience it yet. any thoughts??
is it possible the relief valve on the new spool valve (adjustable, currently set at 2000 psi) is set too high for my system. and when the cylinder travel limit is met, it trips off the auxiliary valve?
thanks in advance...
