4000 hydraulic valve question
Murph
I have a 4000 3 cylinder with a dual hydraulic remote valve mounted under the seat that controls the loader arms and bucket. One of them does not return to center or stays there on it's own and when you lift the arms the bucket moves at the same time unless you manually hold it in the center position. I am guessing there is a spring inside the valve that is broken but I have not found anywhere with an exploded parts view or a rebuild kit. Any thoughts or help would be greatly appreciated. Thanks in advance
There were several dual spool remote valves made over the years that could fit on your 3 cylinder 4000, so we would need a picture to be able to determine which it is to be able to direct you to a parts diagram.
