I have an issue with my Ford 4630. When the key is in the starter position, the engine turns over fine. However, as soon as you release the key to the run position, it turns off. I ran a wire from the electric fuel turn off solenoid to the battery and the tractor continued to run after it started. It looks like a bad connection from the key switch to the solenoid. There is a color coded wire that runs from the solenoid to the engine harness connector and a similar colored wire that continues to the main harness. Somewhere there has to be a relay that switches the current from the start position to the run position. Does anyone have any suggestions?
