marcusmerritt
Ford 2000; 3 cyl. diesel; 8/2 trans....I plan to change the motor oil and hydraulic fluids on my diesel tractor as well as the oil and diesel filters one day soon. The only question I have is the procedure to change out the diesel filter, a single filter. Would the process be: cut off tank valve, remove existing diesel filter, fill new filter with diesel and replace in filter housing, turn tank valve back on? Any other precautions to prevent air in the fuel lines or other woes? Should I let the tractor sit for a couple hours before cranking it to prevent air being sucked into the fuel lines?
Thanks.
Thanks.
