800 flow control oil leak
The flow control on my tractor has leaked oil for 30 years. I have replaced the o rings a few time but can't seem to stop the leak. Is there a secret handshake, witch craft, or some special o rings I'm not using? It's a vane style pump on a 1955.
Can you tell if its coming fron the inside of the oring or the outside of the oring? Clean it with starting fluid and stick the corner of a paper napkin to the area you want to check. Try this place. Marco Rubber
O-Ring Suppliers Kalrez?, Viton?, Silicone, Gaskets, Seals
www.marcorubber.com
EXPERIENCE THE MARCO ADVANTAGE: Need Parts Fast? Millions of O-Rings and seals available for same day shipping supplemented by an integrated worldwide network.
Products & Services
Materials
Reference Guides
Marco Advantage
Contact
Request a Quote
Order Now
O-ring Sizing Dimensions
O-Ring Standard Size Chart USA Standard O-Rings
Parker O-Ring 2- Sizes AS568 O-Ring Spec
Dimensions per AS568 although tolerances vary by use, please see our tolerance pages. Thousands of non-standard sizes are available in stock or can be made within a few weeks typically without tooling fees so no need to settle for a less than optimal fit.
O-Ring Material Selection Compare O-ring compatibility. O-ring material recommendations. O-ring material selection guide.
Need O-Rings Fast? Request a quote to ship today. World?s largest O-ring inventory network. Responsive expert service.
O-Ring Groove Design Guides O-ring groove charts for standard O-ring gland designs.O-ring groove design recommendation FAQs.
Click a Size to Get a Quote
Non-Standard Sizes are our Specialty. Request a Quote Millions in stock or made to order in a few weeks without tooling fees.
Download PDF
McMaster-Carr
www.mcmaster.com
McMaster-Carr is the complete source for everything in your plant. 98% of the products ordered ship from stock and deliver same or next day.
Contact Us
Order
Order History
Log in
View catalog page
Forward
Print
Is this page helpful?
Square-Profile Oil-Resistant Buna-N O-Ring
1/8 Fractional Width, Dash Number 216
Packs of 50
In stock
$8.18 per pack of 50
4061T238
Material Buna-N Rubber
Cross Section Shape Square
Dash Number 216
Fractional
Width 1/8
ID 1 1/8
OD 1 3/8
Actual
Width 0.139"
ID 1.109"
OD 1.387"
Hardness Durometer 70A (Medium)
For Use With Grease
Hydraulic Oils
Specifications Met ASTM D2000, SAE AS568, SAE J200
Temperature Range -30? to 212? F
Color Black
I can't tell exactly where the oil is coming from. Should I be using square profile rings instead of round? There were round rings installed when I took the flow control off the pump originally so that is what I put back.
The parts book calls for a -011 70 duro. I don't really care for hardware/auto parts orings. Since I work on hyd cyls almost day and we buy seals sometimes by the hundreds a day there seems to be a big difference in quality. I would go to your local hyd repair shop. They buy from the previously mentioned places and other companys that specialize in hyds.
