new spool valve
TimPa
So the spool valve on my dunham lehr 22 loader failed (left spool stuck in) and hydraulic shop said they cannot repair. ordered a cross BA2 F2 with float, should be here next week. since i've had the system open now, does anybody any words of wisdom on installing the new valve, bleeding, and making sure i don't get another valve failure? '78 ford 3600
the last valve failed about 10 minutes after remounting the loader after having it off for sickle mowing the fields.
failure caused by???
water, rust, lots of water and contaminants in the fluid?
Mechanical wear and damage
I am guessing it failed due to wear and mechanical damage making the spool stick.. maybe at the notch where the detent locks the spool. rust in detents?
Normally disconnecting and connection are not a problem as the hydraulic ends keep the fluid in the systems. So unless your doing some unusual in the operation or hook up, the valve is designed to operate a loader for years before failure. Disconnects should not bother the system. leaving it with contaminated fluid could cause it to rust in place.
My Farmhand 22 loader has a Gresen valve on it, these valves and the Cross you ordered don't give problems unless they get trash or water in them.
Also sounds like the hydraulic shop didn't try very hard to free it up.
Are you using quick couplers or some form of hard piping, make sure to clean the couples good before plugging them in.
(quoted from post at 08:43:21 08/11/18)
been a great system so far. 1st time removing and reinstalling. has quick disconnects on the auxiliary valve, thought i had everything clean. i figure some spec dislodged and got in the spool. nothing obvious when you look at the spool. he said i couldn't/shouldn't run any abrasive in the valve body. i was tempted to roll up some 400 grit and pass it through... he also said gresen parts are now very $$$
Maybe the valve body had wear or a groove in it that caused the failure. They have to be very very very close tolerances to work correctly. But again, not normally a problem. New loaders are quick 'tach loaders that are removed all the time with no problems.
However, dirt, abrasives, water all can cause problems in any system.
Some of the old timers said that when you plug in a new (used) piece of equipment to your system, that it might have old contaminated oil and will ruin your system. Its much of a wives tale, but there might be some truth to it one in a million times. So, guess your supposed to drain and flush any equipment you buy so you know its clean before connecting to your tractor?????
Another thought,, some tractors (john deere)have contaminated fluid due to brake shoes coming apart. This will destroy the hydraulic pump and anything else in the system. Dont remember if you have wet brakes or not.
have these:
i took real good pics for that. it actually was working for about 5 minutes, noticed left spool valve starting to stick forward (no float) and then it stuck for good.
i agree, he was more interested in selling me a new one when i asked about any repairs. i should have went elsewhere before buying a new one.
