800 Flush Hydraulic Pump With Cover Off???
mrf1002u
Morning,
I am about to put my lift cover back on the 800 and I am cleaning out the center section sump. Really surprised how much muck is in there. On the 800 that is a separate sump correct? Not shared between the diff and trans?
The real question is...I was wondering if there is a way to flush new fluid through the pump after the sump is clean but NOT have the old fluid return to the sump? Just divert the return fluid to a bucket or something until it runs clean?
Thanks,
Larry W.
(quoted from post at 08:40:05 08/10/18) Morning,
Thanks,
Larry W.
emove test port plug at lower right corner (side) of center housing and place catch container under it and block top of pressure tube.
