1967 Ford 4000 Power Steering Cylinder Repair
Has anyone had any experience on rebuilding a Left Hand Single Steering Cylinder used on early 4000 3 cylinder Ford Tractors. I have replaced the ram seal before ,ram is good and not leaking there, but it is leaking at the control valve at rear of cylinder, I am hoping it is just seals leaking not something damaged, please list seal kit # for control valve end, has anyone ever found other problems in valve other than seals, if so what. Thanks
DCPN 3302 A should be what you need. It's at the very end of the parts list at the link below. If for some reason it's no longer available, take the o-rings to any hydraulic shop locally and they should be able to hook you up.
Seal kit
