TW 10 Power Steering pump
Paul in MN
Our TW 10 is losing PS oil and the engine seems to be gaining oil. I suspect there is an oil seal at the front end of the pump which is failing. Son just checked the price of a rebuilt pump through FNH and finds the price to be over $800. We have sufficient PS oil pressure to give normal and adequate steering response, so I don't think we need to go for the rebuilt pump. If you have any experience with the front seal, please share it with us. The tractor is a 1979 vintage and the pump has the self contained reservoir and donut shaped filter inside the reservoir can.
Thanks for your help.
Paul in MN
You need to replace the two seals, #6, in the link below. These seals come in the complete seal kit. I would suggest replacing all of the seals while you're in there, as it just might steer even better after you're done.
Seals
