how much is a 750 backhoe with tractor mount brackets worth?
I'm thinking of selling my ford 750 backhoe tractor attachment with tractor mount brackets and not sure on how much there worth for what to list it for, I had intentions of putting on my ford 3400 but changed my mind ,it's located in Lancaster NY
I would not mind such a backhoe and you are not all that far away. But, no money right now. To answer the question I would think at least a thousand dollars and
possibly more. Readily mounting onto a 3 point hitch would increase the value. What's the story with the open lines and is the pump under the plastic? Lacking pump
and/ or reservoir will hurt value.
(quoted from post at 17:21:12 08/04/18) I would not mind such a backhoe and you are not all that far away. But, no money right now. To answer the question I would think at least a thousand dollars and
I pulled the backhoe off of a blown engine parts tractor, it shared the resivoir with the front loader ,the pump was driven with the loader and had a line going to the backhoe,I had the lines open to take a picture I keep it tarped
Could you take a closeup of the mountings. I have a 750 I plan to mount to a 3400. Mine has under carriage mount that was to smaller Ford tractor, My email is open.
Jim
