730 Loader Fluid Level
KV Bruce
I have a 730 loader on my 3400. With the cylinders retracted, how far below the filler port should fluid be? I haven't had any problems but I just changed some hoses and lost quite a bit of fluid. Thanks
Lift cylinders retracted, bucket level on floor.
Since the loader uses the frame tube for a reservoir, as long as its full to the frame part that goes around to the other side. Fill to 8 inches can cause expansion and it will vent some fluid out on the ground in high temp, long useage. so I allowed a bit less, closer to 12 inches, but again, above,,, where it goes to the main frame tube....
