I bought a 8N last year and it ran ok till you drove down a steep grade.It would suddenly just quit.I thought the float was sticking so I took the carb apart and it looked fine.(it was an aftermarket new carb.)I did this at least 4 times so I finally found a used marvel schebler carb.So I cleaned it,put a new kit in and set the float according to videos I watched.Now it also dies going down steep grade at low throttle speeds.Also on level ground at low throttle the engine will speed up a little then fall off continually till you open throttle up more.Can anyone tell me what the problem could be and how to fix it.I might also mention that when working such as mowing or pulling a disc it does ok with the throttle opened up more.When I cleaned the used marvel carb I sprayed with carb cleaner and blew it out with the air compressor.As far as I could tell all the parts were still in the used carb.In fact they had to take it off the other tractor when I bought it.
Thanks for any help or suggestions.
