Just used it a few days ago but wont start. drained gas out and added fresh. Cleaned all the spark plugs as well. I did not check all the spark plugs but saw a spark
on one when I turned it over. Could see that I was getting fuel in the carburetor as well. I pulled it to the top of the hill and popped the clutch. It fired for a
minute and then lost power. I have been having trouble with fuel leaking into the carburetor when it sits so I have been turning the fuel off when I am done with it.
Somewhere around here I have a rebuild kit but have been putting it off since I am busy and have not done it before so might have trouble.
Should I check the voltage at the coil or spark plugs in case it is too low? What should it be? Any other ideas of where to start.
Also I have an electronic ignition around here somewhere that I bought awhile back. Did not see any directions though. Do you all recommend installing? it anyone have
directions? I bought it from this web site several years ago. My tractor has been switched to 12 volt system
Thanks
Thanks
