Off Road SHO
Hello again,
Been troubleshooting my new to me Jubilee with a 12V negative ground system. At first the can't keep running was traced to poor fuel flow from a clogged fuel filter. Starts and runs much better now, but will still die out after a longer period of pulling. Noticed that it still had the 6V coil in it so bought a new 12v coil. The new coil says to use an external resistor or resistance wiring. I found a ceramic looking resistor under the dash that was not hooked up, and I'm wondering if that needs to go in the line that feeds the coil?
Thanks for any help.
Tom
Tom
