marcusmerritt
Ford 2000; 3 cyl. gas. 1965 model year; 4/1 trans....I bought a set of headlights to add to my tractor before I sell it to my brother and have a couple questions.... What wire gauge would work best: 16 gauge; 14 gauge, heavier?? Are the lights grounded via their bolted connection to the body metal or do I need to ground them to the frame??
Please advise if this wiring connection will work: connect hot wires from both headlamps and run to the switch; run hot wire from switch to a battery connection. What's the best place to connect the hot wire to the battery, at the voltage regulator??
Thanks.
Thanks.
