perryjosh64
I’ve posted on this before but forgot a detail. This is on a 64 Ford 2000 gas tractor w/ 4 speed trans. I have a slow hydraulic leak that I assume is coming from transmission because hydraulics and rear end seem to maintain fluid level but have to add to transmission periodically. The fluid leaks from square plate/coter pin. The part I left out seems it is also leaking from around PTO Shaft. I say this is because after mowing with bushhog plate below PTO shaft and drawbar look “wet” with hydraulic fluid?
Could trans be leaking out of PTO shaft & bell housing and I need to replace PTO rear seal? Or do I have a trans leak and a hydraulic lift leak as well to deal with? Again everything works fine and the leak is slow just thinking of when I get around to fixing them where to start.
