tysmobiletractor
I’m doing fluid changes in a Ford 860
I have drained all:
Hydraulic fluid
Rear axle fluid
Transmission fluid
Bit confused on the compartments in the housing. There are 3 big plugs to refill. The center plug in the lift housings appears to be open to the buttons. So this center portion holds hydraulic fluid that is checked by the dipstick by the pto lever? And this fluid is separated from the rear axle oil and the front transmission oil?
Am I correct?
My service manual seems vague in this matter.
I was planning to use 80-90 for axle and transmission. And universal hydraulic for the center.
Any pointers on pros and cons of this. ?
Or other recommendations?
Thanks
I have drained all:
Hydraulic fluid
Rear axle fluid
Transmission fluid
Am I correct?
Thanks
