Thanks guys, I appreciate the input. I will pull the clutch housing inspection cover and take a look. I will keep you posted.(reply to post at 03:59:07 07/18/18)
(quoted from post at 11:27:30 07/18/18) There is no clutch inspection cover on a Ford. Only way you can see the clutch is to split the tractor at
the motor/transmission
(quoted from post at 09:12:55 07/18/18) I had an 861 that was 1955.
(quoted from post at 17:46:06 07/18/18)(quoted from post at 11:27:30 07/18/18) There is no clutch inspection cover on a Ford. Only way you can see the clutch is to split the tractor at
The hundred and '01 series 5 speed transmissions have a removable plate on the bottom of the bell housing area that has the hole with the cotter pin in it. The parts drawing calls the plate a "transmission inspection hole cover".
(quoted from post at 08:33:27 07/19/18) I dont know why the pto would work though as it has to have gears turning it.
