Lift control quadrant
mike maxwell
New User
I need to replace the friction disc on my lift control quadrant but I can t get it off. I was going to use a puller but I can t find one
with thin enough jaws to get behind it, any suggestions.
(quoted from post at 15:03:01 07/12/18) I need to replace the friction disc on my lift control quadrant but I can t get it off. I was going to use a puller but I can t find one
ven if you did find puller, it would break anyway. Sometimes soak with penetrant and very mile heat (melt very easily), but I always buy new plate along with cork part.
I recently replaced the friction disk, following instructions found (see 'Dollar Bill's' reply to "Ford 600 Friction plate troubles in reply to britth, 04-29-2018 14:31:03") on the forums. To get the friction plate off, heat it slightly with a propane torch, then gently pry off with a screwdriver, alternating sides. It is aluminum and will expand at a different rate than the shaft, breaking any adhesion.
