marcusmerritt
Ford 2000; 3 cyl gas and diesel....Went out this evening to swap out the new rims and tires off the gasser and to put them on the diesel but the rims on the gasser seem to be stuck (yes, I did remove the lug nuts). Took one of the diesel fronts off and it came off just fine. Before I go whanging away with a large hammer, wanted to see if there is a secret way to remove the rim/tire from the gasser. I'm assuming that there is just a tight fit of the rim onto the hub but figured you guys on the forum might have come across this problem before and would have sage advice. Thanks.
