1965 Ford 5000
JPK
Temp and Fuel gauge quit working yesterday at the same time cutting hay. What
would be the most likely problem. Thank all of you over the years yall are a great
bunch with a ton of knowledge.
Phil in Tn
Fuse blown, it's located in the wiring harness behind the dash, 4 screws hold it in, if it's original the nuts are molded into the rubber and are bad about rounding out.
Look for bare wires while the dash is out, mice like to build nest under there and chew on the wires.
