TractorLinks.com
Order Ford 4000 Parts Online
4000 select o speed starting issue
Martinmanhd28
07-12-2018 05:00:21
I have to move shifter to get it to start. Can anyone tell me if the cable needs adjustment or is electrical the issue
showcrop
07-13-2018 18:48:49
 Re: 4000 select o speed starting issue in reply to Martinmanhd28, 07-12-2018 05:00:21
I would say that it is close enough and gets the function across plenty well enough to earn a cigar in my book.
Larry NCKS
07-13-2018 16:42:39
close . . . but no cigar! 8) The cam closes the safety start switch to provide a ground for the starting system.
Martinmanhd28
07-13-2018 04:31:20
Ok thank you, I found out it’s a 63 and i ordered my manuals for it.
Martinmanhd28
07-12-2018 09:29:42
Just bought the tractor and in another post I gave the serial number.
Not sure yet what year but maybe 63.waiting on help with that. I wanted to be sure what year it is before I purchased any manuals.
Thanks for the info and help.
Martinmanhd28
07-12-2018 09:22:59
Ok thanks for the info
Larry NCKS
07-12-2018 08:06:24
Yep! Cable adjustment.
tequila
07-12-2018 07:19:09
You did not mention what year 4000, however I think they are all similar. The start safety switch is mounted inside the top cover and is activated by a cam that opens the switch when the shift selector is in park. That position is rather touchy but cable adjustment usually all it needs. As stated by others, use the manual for your model.
Bern
07-12-2018 06:15:42
If bumping the shifter makes it start, it's obviously a cable adjustment issue to me.
showcrop
07-12-2018 05:59:27
Since the knob needs to be all the way down to start, and assuming that by "move" you mean that you have to persuade the knob to go a little more than where it wants to be in order for the starter to crank, it certainly sounds like you need to take up on the cable a little. Consult your manual.
