ptfarmer
- Location
- San Antonio, Tx
I got my 71 Ford 4500 industrial running, during the rebuild I switched over from the generator to a one wire alternator with the cable tach drive which turns clockwise. I don't like the original Ford instrument cluster they used as has anyone found a regular round tach like what the Farmtrac, or whatever they call it that will work using the existing cable. I had a old tach from a MF gas tractor that was clockwise, it reads twice as fast, but the Ford cable end screwed right on. I'm also looking for a fuel level, and coolant temp gauge that works with the original senders, anyone know of any gauges that will work with the original senders, or do I need to adapt/get different sending units. Thanks
