Hi guys.
Today my rebuild engine had it's first test, oil pressure while cranking. No oil pressure came, so i searched this forum, and many said "prime the pump" so I did. And boom, 50psi pressure while cranking
But in the "no pressure" confusion, my thoughts went to the oilpump. I bought a brand new one, and remembered seeing that it had a threaded hole for a bolt. The old pump had a bolt with a bit washer on it, threaded into that hole. But none of the drawings online or in the manual showed this bolt:
https://partstore.agriculture.newholland.com/us/parts-search.html#epc::mr52323ar361589
So I didn't put it in the new pump. What is that bolt for?
Its this one:
Do I need to take off the oil sump and put it in the new pump?
Its this one:
