Another 850 update
WI Dave
Re-checked timing of dist, hooked up the coil the right way, and it fired right up. After 2 or 3 years of not running, it's now running
like a champ. Now I have 2 questions: What's a good fluid to put in the loader? What should I fill the PS reservoir with? Thanks!
UTF in th loader. The owners manual for the 801 series calls for ATF type F for the power steering. I use Dextron 4 which is a all brands ATF
We had some ATF in the shed, so I filled the reservoir, and the PS works fine. It runs good and idles smooth, ammeter seems to work, tach and cable are broken. The only problem I have now is that the gas tank is leaking from the front mounting stud area.
