Hi Guys.
So it was time to refit the renovated engine to the gearbox.
It went smoothe until the last 2mm.
The splines seems to lock in, while still gapping 2mm there is no problem turning the engine by wrenching the crankshaft. But when I tighten the engine the last 2mm on to the gearbox, I'm unable to turn over the engine.
The gearbox is in neutral while trying this..
After adjusting the clutch lever, the clutch feels normal, but enganging the clutch dosent solve the problem.
I have tried to taking it apart and try again, same resault.
I have fittet a new clutch plate if that makes any difference..
Any thoughts?
Any thoughts?
