sammorgan3
One of the factory screws was too long on mine. I swapped them over one at a time from old pump to new, so I know I had them in the right place. Took a closer look and the new pump (Complete with flimsy aluminum casting and janky plastic impeller) has a boss for this screw about 1/4" shorter than the original piece. Only this one boss is shorter, the rest are the same, even if all the holes are huge compared to the original. :roll:
So if your tractor is in a remotish location save yourself a trip and take a 3/8-16 x 2-3/4 along with you. May want to grab a 2-1/2 as well just to be sure.
